Babbage
Dec 13, 2014Aspirant
6.2.0 upgrade problems on RN104
Since upgrading my RN104 to 6.2.0 I've had similar problems to those listed by other users: - Unable to shutdown or reboot. Display shows appropriate message and power button LED flashes, but noth...
Dec 23, 2014Guru - Experienced User
ReadyNAS doesn't have a mode that spans drives like the one you describe for dlink. It would be convenient, though of course you wouldn't be sure what data you'd lose if particular drive fails. Not sure how it would handle folders that are larger than a single drive.
Babbage wrote: Netgear use JBOD to refer to each drive being a separate volume (as per my current setup) but D-Link call this Standard, with JBOD meaning all the drives combined into one volume but not striped like RAID 0. As far as I can tell, it just fills up the drives in turn as you copy data to the single volume, so one drive failing will only take out the contents of that drive. Isn't there an option to do this in the ReadyNAS? I'll take security of my data over speed any day!
Anyway, as long as you know the implications of RAID-0 and have a solid backup strategy in place that takes those limitations into account, then you should be fine.
