Davexyz2
Oct 12, 2015Aspirant
6.4.0 update and USB disks
I have updated to v6.4.0 on my 104's and a number of file issues have cropped up with t usb discs attcahed upon the reboot the disk names have all changed ie from USB_HDD_1 to xxx_xxx_3 or mor...
okulo
This happened to me after I updated to 6.2.5 and has just happened again. I posted the problem back in August along with the workaround - it's not a fix because it doesn't return the USB drive to its original ID:
It's disappointing, to say the least, that this issue has not been addressed.
- okuloOct 12, 2015Aspirant
I should add that I just tried this workaround and there was no option to reset permissions on the USB share. In fact, there are no options under File Access at all and probably as a result of that, it doesn't work.
Whilst I was unable to find a way to reset permissions as per the instructions I was given in the thread to which I linked, and unable to enable Guest Access, per se, I just searched through the settings and found 'Allow anonymous access' which has got rid of the previous USB ID; it just remains to be seen if the backup to it is successful with the new ID I had an e-mail this morning stating that it had failed.
