adudley1
Oct 18, 2015Aspirant
6.4.0 with RN104 - No Longer Shuts Down. Any Ideas?
Hey Guys, Ive been using My RN104 for a while, but since upgrading the firmware as per the login page the ReadyNas no longer shuts down. Ive tried the pressing the power button and follow the...
BrianL2
Oct 18, 2015NETGEAR Employee Retired
Hi adudley1,
Welcome to the community!
Try to disable the disk spin (schedule) as well as the power time feature then reboot the ReadyNAS using the shutdown icon in the admin page.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
adudley1
Oct 22, 2015Aspirant
HI there,
I did try that and it does work, although its been intermitant over the last few days (sometimes it shutsdown, other times it hangs). Currently got an L2 ticket with netgear and even though NAS is on they are saying that the logs say its sucessfully turned off. So still in limbo on the subject.
But many thanks for the seggestions and i expect it will work well for most people :)
Aaron
- BrianL2Oct 24, 2015NETGEAR Employee Retired
Hi adudley,
Thanks for the feedback. Since you can login to the admin page, could you try to run volume balance and see if it will help?
Kind regards,
BrianL
