YorkBoy
Dec 05, 2015Luminary
6.4.1 and the problems from 6.4.0 are still there. #26140511
I have a 102 and all was fine on 6.2.5
Then I updated to 6.4.0. and all USB backups failed as it seems as has happened with others.
Now updated to 6.4.1 and on attempting a USB backup the...
YorkBoy
Dec 06, 2015Luminary
Further update.
It seems that for some reason my front socket on my 102 if used causes the unit to freeze even though I have always used this socket and the backup button in the past.
I have just altered my settings to enable this backup to be performed from the back upper socket.
All went well except it was very slow.
But even though the NAS 'ejected' the stick it still continues to appear on my shares. This is the very same problem I had when I first bought the unit which was given the title 'ghost shares'. It took ages to sort.
However on then plugging in a WD hard drive to perform a complete backup even though this was successful it took three times as long as it used to and strangely the 'ghost share' now shows excatly the same storage capacity as this WD drive as if its a mirror of it.
Have sent the information to Netgear but hold out little hope that this will be delat with quickly.
I have also asked if, now that I have an up to date back up, if I can factory reset my NAS and force it to reinstall 6.2.5 which worked a treat. No response from Netgear.
You really have to ask yourself how such a thing can be allowed to happen? I run no apps, just a standard 102 with a very basic setup.
If I ever get this going again I will never update my firmware, leave well alone.
In sheer frustration I went to order a WD NAS but stopped the order. I'm now thinking that was a big mistake.
Dec 06, 2015Guru - Experienced User
See ifixidevices post on this thread: https://community.netgear.com/t5/ReadyNAS-Beta-Release/Downgrading-from-6-4-0-to-6-2-4-with-a-Pro-Pioneer/td-p/1006544
Netgear doesn't recommend that method, but it seems to have worked for the people who tried it.
