JanHussaarts2
Dec 27, 2016Luminary
^6.6.1 Beta 4 Disks spinning down or up
I've installed the lates beta and see the disks going to sleep and waking up regardless of the settings. Furthermore in the settings in the UI under Disk Spin Down, I can only select of deselect dis...
- Jan 07, 2017
Installing the official 6.6.1 release seems to have solved the problem.
Dec 28, 2016Guru - Experienced User
What model ReadyNAS are you seeing this on?
- JanHussaarts2Dec 28, 2016Luminary
On my legacy ultra 6
- mdgm-ntgrDec 29, 2016NETGEAR Employee Retired
Which services are you running?
Which apps are you running?
Which firmware did you update to 6.6.1 Beta 4 from?- JanHussaarts2Dec 29, 2016Luminary
6.6.0 Beta 1, patched by Skywalker because of problems with the fans.
I decided to install the latest beta because after a restart the 6.6.0 version did not see the volumes.
Only after a second or third restart it recognised them and took some time to scan the volumes.
I'm running Owncloud with MySQL.
The difference with before is that I've attached another UPS (APC) and configured the shutdown at 50%.
