JanHussaarts2
Dec 27, 2016Luminary
^6.6.1 Beta 4 Disks spinning down or up
I've installed the lates beta and see the disks going to sleep and waking up regardless of the settings. Furthermore in the settings in the UI under Disk Spin Down, I can only select of deselect dis...
- Jan 07, 2017
Installing the official 6.6.1 release seems to have solved the problem.
JanHussaarts2
Dec 28, 2016Luminary
On my legacy ultra 6
mdgm-ntgr
Dec 29, 2016NETGEAR Employee Retired
Which services are you running?
Which apps are you running?
Which firmware did you update to 6.6.1 Beta 4 from?
- JanHussaarts2Dec 29, 2016Luminary
6.6.0 Beta 1, patched by Skywalker because of problems with the fans.
I decided to install the latest beta because after a restart the 6.6.0 version did not see the volumes.
Only after a second or third restart it recognised them and took some time to scan the volumes.
I'm running Owncloud with MySQL.
The difference with before is that I've attached another UPS (APC) and configured the shutdown at 50%.
- mdgm-ntgrDec 29, 2016NETGEAR Employee Retired
Can you send in a fresh set of logs (see the Sending Logs link in my sig)?
- FramerVDec 29, 2016NETGEAR Employee Retired
Hi JanHussaarts2,
Just would like to do a follow-up. We would like to request for your system logs.How do I send all logs to ReadyNAS Community moderators?
