rodcrit
Oct 28, 2017Luminary
6.9.0 firmware update
since the update was installed - my NAS is continually showing activity on the discs. before update the unit remained quite and silent for the majority of the time. it is now chuntering away con...
- Oct 28, 2017
Disable "File Search" on the GUI System/Overview tab I guess
mdgm-ntgr
Oct 28, 2017NETGEAR Employee Retired
Are you remembering to login to SSH as the user 'root', not 'admin'?
rodcrit
Was remembering that, but was forgetting to use 'root'. That part all ok now thanks.
Rod
- mdgm-ntgrOct 28, 2017NETGEAR Employee Retired
O.K. now that you're in have you checked the output e.g. of
# top
to see if a process is using lots of resources?
- rodcritOct 28, 2017Luminary
OK -- yes a process called "tracker-minor-f is using ~89%
and tracker-extract ~22%
those are by far the largest user of resources... but dont have clue what they are doing !
as you can see from the attached screen dump - they are varying quite a bit
