rgerrits
Aug 22, 2018Aspirant
6.9.3 : Bug with static ip adresses
Situation:
I configure static IP address and DNS server on eth0 via ReadyNAS webgui
Static DNS server shows up in resolv.conf:
root@NAS2:~# cat /etc/resolv.conf
# Generated by Connection ...
Retired_Member
Aug 23, 2018Hi rgerrits, would it be possible to also use your router to assign the concerned ip-address (ip4, ip6, or both) to your nas?
rgerrits
Aug 24, 2018Aspirant
Of course that is possible, but that is besides the point.
If GUI offers a way to use static IP addresses, then it should work properly.
I managed to work around this by manually fixing dhcpd.conf, but Netgear should fix this for ppl that do not want to enable ssh.
One could even see this as security bug. An attacker could place a DHCP server in the same subnet to change DNS and even default gateway that were staticly defined and via that way become man in the middle.
(But of course if an attacker has access to your network, then you may have bigger issues.)
- StephenBAug 24, 2018Guru - Experienced User
DHCP isn't a secure protocol to begin with, so that's a hard case to make. DHCP clients will discover and respond to the attacker's server, and it can set the gateway and subnet mask to force all traffic from those clients to a man-in-the-middle server. That's already toxic - having it touch a few more devices that use static addresses doesn't make it much worse. Yes, the attacker could climb through that window, but why bother - the door is standing wide open.
FWIW, I use DHCP with reserved addresses, and I haven't seen my configured DNS servers change on the NAS. That said, as long as the DNS servers resolve correctly I might not.
Netgear should look at this, since your analysis does suggest something isn't quite right.
- rgerritsAug 24, 2018Aspirant
Also, the change is not visible in the GUI, so you could only see it by looking at /etc/resolv.conf
