Erik-NA
Aug 14, 2016Aspirant
GS728TP managment IP-adress leased through DHCP even if static address is configured
I have configured the switch to use static IP-address for managment using a separate VLAN, VLAN 123. The web gui is accessible through this IP-adress.
For unknwon reason, the switch is leasing an managment IP-adress on VLAN 1 through DHCP. The web gui is also accessible through this IP-address.
The two VLANs has no common membership on any port on the switch. The only cable connected to the switch is the DHCP server on VLAN 1
When looking at the IP-configuration in the web management interface, the default gateway field value is the gateway address from the DHCP-server, but the IP-adress for the switch is the static one.
Software version: 6.0.1.18
Boot verson: 2.0.0.11
Thanks for you suggestion. I solved it another way.
1. Changed managed VLAN id to 1.
2. Changed port to VLAN 1 and logged in, saw that default gateway field was empty. Inserted correct parameter and applied.
3. Changed back to original managed VLAN id
4. Problem solved.
I couldn't change to DHCP, got an error. But this did it
- DaneANETGEAR Employee Retired
Hi Erik-NA,
Welcome to the community! :)
Kindly try the steps below:
a. On the web-GUI of the GS728TP switch, go to System > Management > IP Configuration.
b. Select Dynamic IP Address (DHCP) then click Apply.
c. Select Static IP Address then re-enter the static IP Address you've assigned as well as the Subnet Mask and Default Gateway.
d. Click Apply.
e. Observe if same problem occurs.
Let us know the results.
DaneA
NETGEAR Community Team- Erik-NAAspirant
4. Problem solved.
Hi Erik-NA,
I'm glad that the problem is now resolved. :) I appreciate that you have shared the steps you did to solve the problem.
Feel free to post your future concerns here in the community.
DaneA
