rgerrits
Aug 22, 2018Aspirant
6.9.3 : Bug with static ip adresses
Situation:
I configure static IP address and DNS server on eth0 via ReadyNAS webgui
Static DNS server shows up in resolv.conf:
root@NAS2:~# cat /etc/resolv.conf
# Generated by Connection ...
kohdee
Sep 06, 2018Administrator
We use Connection Manager to manage all network connections, not dhcpcd/udhcpc. Is it possible you installed some apps or some programs, perhaps some network tools package, or you did an apt-get upgrade?
Connman's adapter configurations exist in /var/lib/connman. dhcpcd.conf is not a standard ReadyNASOS config file. You might want to inspect your device further and find out why your ReadyNAS is using dhcpcd at all. If you are paranoid, perhaps the support team can wipe your OS and rebuild it from scratch to give you back a pristine ReadyNASOS install while keeping your data as it was.
