ifixidevices
Feb 09, 2015Luminary
8TB drives in pro 6?
I'd like to get two 8TB drives and shove them in my Pro 6 running OS6... any reason why I couldn't? I can get two for $279 a piece from newegg business: http://www.neweggbusiness.com/product/p ....
CharlesR
Feb 09, 2015Guide
ifixidevices wrote: I can get two for $279 a piece from newegg business:
Keep in mind the warranty is via the external enclosure as the drive's serial number is assigned to it. So be careful opening it up (so you can reassemble it without them knowing :)) or you will be out of luck if the need arises.
