onrofla
Mar 07, 2017Aspirant
8TB ST8000NM0055 with ReadyNAS Pro 6 - so far, so good
My report: One week in, RNDP6000 (no suffix on label) Pro 6, with 6x ST8000NM0055 (f/w SN02) - working fine. This drive is NOT on the HCL, repeat my foolhardy example at your own risk, blah, blah, ...
Mar 08, 2017Guru - Experienced User
Thx for posting your experience with these drives. It'll help inform other folks when they are looking at drive upgrades.
This drive is NOT on the HCL, repeat my foolhardy example at your own risk, blah, blah, blah.
They aren't updating the HCL anymore - I've recommended selecting disks from current enterprise-class or NAS-purposed drives for some time now. Tracking down old drives from the HCL makes little sense to me.
I see you are also running OS 6. There are expansion limits with OS 4.2 firmware that start to get in the way if you are using 4 TB or larger drives. Switching to OS 6 is a reasonable solution, especially if you are out of warranty.
onrofla wrote:
...These 8TB Disks suffer from the annoying whine at idle, as reported on other threads.
Seagate says a new drive f/w will be realeased soon (March 2017 or thereafter). Noise will be fixed by what they say is an adjustment to "step sweep seek value" in firmware.
Some posters here seem to have gotten updated firmware already. "March 2017" is now of course, but if there is delay you might push Seagate a bit.
