Dickert
Feb 13, 2017Aspirant
90% CPU usage by readynasd
Good morning, since an automatic and unplaned system shutdown the ReadyNas is very slow. Web access is also not possible. Via SSH access I saw that the readynasd process needs full CPU power....
- Mar 02, 2017
Somehow (I have no idea how) your rsync config file had nul bytes in the middle of it. This cause our config parser to go into an infinite loop. I fixed the config file locally on your box, so you should be up and running normally. We will also have a firmware fix for handling this strange situation gracefully in 6.7.0.
mdgm-ntgr
Feb 13, 2017NETGEAR Employee Retired
Which firmware are you running?
Have you checked how full the root volume is?
# df -h # df -i
- DickertFeb 13, 2017Aspirant
Good question regarding the firmware version. Is there a chance to find it out via SSH? I have no Web access.
Disk space I chacked already:
df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 834M 2.9G 22% /
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 440K 248M 1% /run
tmpfs 125M 0 125M 0% /run/lock
tmpfs 249M 0 249M 0% /sys/fs/cgroup
/dev/md126 3.7T 2.1T 1.6T 57% /FotoArchiv2
/dev/md127 3.7T 3.3T 422G 89% /BackUp
/dev/md126 3.7T 2.1T 1.6T 57% /home
/dev/md126 3.7T 2.1T 1.6T 57% /apps-------------------------------------------------------------
df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 63155 392 62763 1% /dev
/dev/md0 65536 15440 50096 24% /
tmpfs 63590 1 63589 1% /dev/shm
tmpfs 63590 511 63079 1% /run
tmpfs 63590 3 63587 1% /run/lock
tmpfs 63590 9 63581 1% /sys/fs/cgroup
/dev/md126 0 0 0 - /FotoArchiv2
/dev/md127 0 0 0 - /BackUp
/dev/md126 0 0 0 - /home
/dev/md126 0 0 0 - /apps-------------------------------------------------------------
