Dickert
Feb 13, 2017Aspirant
90% CPU usage by readynasd
Good morning, since an automatic and unplaned system shutdown the ReadyNas is very slow. Web access is also not possible. Via SSH access I saw that the readynasd process needs full CPU power....
- Mar 02, 2017
Somehow (I have no idea how) your rsync config file had nul bytes in the middle of it. This cause our config parser to go into an infinite loop. I fixed the config file locally on your box, so you should be up and running normally. We will also have a firmware fix for handling this strange situation gracefully in 6.7.0.
Skywalker
Mar 02, 2017NETGEAR Expert
