thecitycup
Apr 18, 2013Aspirant
A couple of questions on readyNAS NV+
Hi Guys, I am not sure if it is permitted to put forward the following questions, if not, please kindly let me know. a. The system will do re-sync after every manual reboot. How to configure to...
Apr 19, 2013Guru - Experienced User
Normally it will only do a file check if there was a clean shutdown. If it is resyncing, there should be information in the logs which indicate the reason.
thecitycup wrote: a. The system will do re-sync after every manual reboot. How to configure to disable such operation, please?
thecitycup wrote: b. Can it support Raid 10 in ReadyNAS NV + with RAIDiator 4.1.10, please?
RAID-10 is available on 6-bay or greater ReadyNAS only. So it would not be available on an NV+
thecitycup wrote: c. I also buy one UPS for it, but not find a suitable buyer. Can you please give me some advice?
I use a CyberPower CP1350AVRLCD with my NV+ and Duo, it has worked well for me. APC is another brand that many people buy.
