XtheUnknown
Jan 01, 2025Apprentice
Aall shares have disappered from the web UI
Annoyingly, my system restarted itself unexpectedly at around 10pm last night and when it came back up, all the shares (except for home folders) had disappeared from the shares tab of the web UI, alt...
- Jan 02, 2025
XtheUnknown wrote:
df -h is showing /dev/md0 partition is 36% (of 4G) used but
btrfs file usage // shows only 330 MB unallocated (of 4GB).
Run a balance
btrfs balance //That should increase the unallocated space.
FWIW, running out of unallocated space could have triggered your problem.
XtheUnknown
Jan 02, 2025Apprentice
All those log files have been overwritten since the event, except STATUS.LOG which just confirms that ReadyNASOS service was restarted at 22:38:12 on 2024/12/31.
Yes, I have a full backup on another ReadyNAS, so if files have become corrupted I could potentially factory reset and restore the whole system from backup (although I'd rather not go through that!)
I've also (now) downloaded and run the "codycook" share_lun_ui_fix.sh script which (as my shares had already re-appeared following my restore of the configuration file and subsequent reboot) does not appear to have done any harm (and hopefully has tweaked anything not fixed by my initial approach)
Jan 02, 2025Guru - Experienced User
Run a balance
btrfs balance //
