Piglet
Jul 09, 2015Luminary
Aborting a balance
I'm running 6.2.2 on a RN104 with 3x3TB and scheduled a balance a couple of days ago. I had 25GB free, which seems to cause the balance to take a very long time. After about 20h the display stil...
Piglet
Jul 23, 2015Luminary
So here's what happened.
I waited close to two weeks for the balance to complete but when it hadn't done so I finally pulled the cord.
It rebooted normally after that, it also automatically restarted the balance (at 0%). Which I stopped gracefully now that I had ssh access again.
I found that the filesystem had been damaged when I was trying to delete some files and the filesystem suddenly turned read-only. I gather this is a feature of btrfs, so when something unexpected happens it prevents more damage. A reboot resets the filesystem to the normal read/write.
In order to fix the damaged filesystem I have tried a full scrub (which took 2 days and reported no errors) as well as a new balance (with smaller -dusage values) but the problem still remains.
The kernel.log messages end with the following:
Jul 21 18:15:54 Nasse kernel: WARNING: at fs/btrfs/super.c:255 __btrfs_abort_transaction+0xa4/0xf0() Jul 21 18:15:54 Nasse kernel: btrfs: Transaction aborted (error -2) Jul 21 18:15:54 Nasse kernel: Modules linked in: vpd(P) Jul 21 18:15:54 Nasse kernel: Backtrace: Jul 21 18:15:54 Nasse kernel: [<c003c51c>] (dump_backtrace+0x0/0x110) from [<c061e304>] (dump_stack+0x18/0x20) Jul 21 18:15:54 Nasse kernel: r6:000000ff r5:c02d1bec r4:c46c3c78 r3:00000000 Jul 21 18:15:54 Nasse kernel: [<c061e2ec>] (dump_stack+0x0/0x20) from [<c006ab4c>] (warn_slowpath_common+0x54/0x70) Jul 21 18:15:54 Nasse kernel: [<c006aaf8>] (warn_slowpath_common+0x0/0x70) from [<c006ac0c>] (warn_slowpath_fmt+0x38/0x40) Jul 21 18:15:54 Nasse kernel: r8:0000160d r7:c063f74c r6:d4d9f000 r5:d4e2c680 r4:fffffffe Jul 21 18:15:54 Nasse kernel: r3:00000009 Jul 21 18:15:54 Nasse kernel: [<c006abd4>] (warn_slowpath_fmt+0x0/0x40) from [<c02d1bec>] (__btrfs_abort_transaction+0xa4/0xf0) Jul 21 18:15:54 Nasse kernel: r3:fffffffe r2:c0753e18 Jul 21 18:15:54 Nasse kernel: [<c02d1b48>] (__btrfs_abort_transaction+0x0/0xf0) from [<c02e24d8>] (__btrfs_free_extent+0x5a0/0x8cc) Jul 21 18:15:54 Nasse kernel: r8:d9f2a240 r7:00000000 r6:001020d8 r5:00000000 r4:00000000 Jul 21 18:15:54 Nasse kernel: [<c02e1f38>] (__btrfs_free_extent+0x0/0x8cc) from [<c02e6638>] (run_clustered_refs+0xa1c/0xe90) Jul 21 18:15:54 Nasse kernel: [<c02e5c1c>] (run_clustered_refs+0x0/0xe90) from [<c02ea530>] (btrfs_run_delayed_refs+0xbc/0x528) Jul 21 18:15:54 Nasse kernel: [<c02ea474>] (btrfs_run_delayed_refs+0x0/0x528) from [<c02f9fbc>] (btrfs_commit_transaction+0x90/0x8f0) Jul 21 18:15:54 Nasse kernel: [<c02f9f2c>] (btrfs_commit_transaction+0x0/0x8f0) from [<c02f3840>] (transaction_kthread+0x1b0/0x1c4) Jul 21 18:15:54 Nasse kernel: [<c02f3690>] (transaction_kthread+0x0/0x1c4) from [<c00843f0>] (kthread+0x8c/0x94) Jul 21 18:15:54 Nasse kernel: [<c0084364>] (kthread+0x0/0x94) from [<c006e1f8>] (do_exit+0x0/0x6a8) Jul 21 18:15:54 Nasse kernel: r6:c006e1f8 r5:c0084364 r4:d46d3cc0 Jul 21 18:15:54 Nasse kernel: ---[ end trace 464cda4a3b14cdb0 ]--- Jul 21 18:15:54 Nasse kernel: BTRFS error (device md127) in __btrfs_free_extent:5645: errno=-2 No such entry Jul 21 18:15:54 Nasse kernel: BTRFS info (device md127): forced readonly Jul 21 18:15:54 Nasse kernel: BTRFS debug (device md127): run_one_delayed_ref returned -2 Jul 21 18:15:54 Nasse kernel: BTRFS error (device md127) in btrfs_run_delayed_refs:2688: errno=-2 No such entry
Any suggestions to repair this? I've read about btrfsck but I wanted to check if there's other options before doing that since it seems like a last option.
Also, I'd like to suggest that ReadyNAS always pauses any btrfs operation like balance before it reboots instead of waiting for it to complete. In order to prevent things like this from happening.
mdgm-ntgr
Jul 23, 2015NETGEAR Employee Retired
Do you have a backup? If not I would suggest backing up your data (if you can) as the next step.
We have a change coming in a future firmware release to attempt to cancel any running balances before shutting down.
Please send your logs in (see the Sending Logs link in my sig)
- PigletJul 24, 2015Luminary
Good to hear that future versions might avoid this problem. As for my current issue; I don't have a backup but I'm working on finding space for the data and making copies at the moment.
I have sent you the logs.
- PigletAug 12, 2015Luminary
I have now copied all my data off the NAS.
Unfortunately I lost a 400GB directory after moving it to a connected USB disk using the web interface. After leaving the copy overnight I woke up to a frozen NAS. I had to cut the power to reboot it. The logs indicated it had gone into read-only mode again and the directory I had copied had been deleted, but the disk appeared empty. Using a recovery software I eventually found about 200GB of the files although most of them without filenames, so it will take a long time to piece together what is what.
I ran "btrfs check" on the disk:
# btrfs check /dev/md127 Checking filesystem on /dev/md127 UUID: 34bda540-18c4-4437-b708-f7d6d81b53c3 checking extents checking free space cache cache and super generation don't match, space cache will be invalidated checking fs roots checking csums checking root refs found 1762329360808 bytes used err is 0 total csum bytes: 1047206540 total tree bytes: 2745073664 total fs tree bytes: 1211465728 total extent tree bytes: 228753408 btree space waste bytes: 484263440 file data blocks allocated: 67038373376000 referenced 5557936832512 Btrfs v3.17.3
After doing that I tried once again to delete files, but it again triggered the errors leading to the read-only state.
Is there anything else I could try before giving up and reformatting everything?
- mdgm-ntgrAug 13, 2015NETGEAR Employee Retired
Sent you a PM
