shadow3135
Jul 26, 2018Aspirant
Access Denied and other issues
Hello,
I am having an issue where I cannot copy files or create folders on the readynas 2120 over SMB. I also cannot create new shares, delete files, or whitelist IP addresses for access. The a...
- Aug 08, 2018
Hi shadow3135,
It appears that the file system has gone ready-only. We cannot see on the logs what would have caused the issue. It will be best if you contact NETGEAR support so they can fix this. Please note that if the NAS is already beyond the support warranty, they might require you to purchase support contract or a pay-per-incident support.
Jul 26, 2018Guru - Experienced User
Do you have a quota set on the share?
- shadow3135Jul 26, 2018Aspirant
We do. Its 10 TB. we have not met the quota yet and I cannot turn it off. It will not let me. The error I get is Commit failed. I added a screen shot.
- StephenBJul 26, 2018Guru - Experienced User
You probably need Netgear's help on this one.
- JohnCM_SJul 26, 2018NETGEAR Employee Retired
Hi shadow3135,
You may provide to us the NAS system logs so we can check what is causing the issue. Please check this link for the steps on how you can send it.
Hi John,
I just emailed them over. Subject is Forum Post: Access Denied and other issues
