shadow3135
Jul 26, 2018Aspirant
Access Denied and other issues
Hello,
I am having an issue where I cannot copy files or create folders on the readynas 2120 over SMB. I also cannot create new shares, delete files, or whitelist IP addresses for access. The a...
- Aug 08, 2018
Hi shadow3135,
It appears that the file system has gone ready-only. We cannot see on the logs what would have caused the issue. It will be best if you contact NETGEAR support so they can fix this. Please note that if the NAS is already beyond the support warranty, they might require you to purchase support contract or a pay-per-incident support.
shadow3135
Aug 01, 2018Aspirant
Hi John,
I did that but it didn't help. I can't even SMB into the shares any longer. I get access denied. That hasn't happend before. I've rebooted multiple times, tried to delete files from the web portal, and remove all quotas.
JohnCM_S
Aug 08, 2018NETGEAR Employee Retired
Hi shadow3135,
- shadow3135Aug 09, 2018Aspirant
Thank you for your help. We are probably going to be moving on from these devices given there age.
