dim73
Dec 04, 2012Aspirant
Access HD in USB enclosure
Hello, When my ReadyNAS dies but the HD is still working, can I still have access to the HD when I put it in a USB enclosure? Can I mount the HD in OSX or do I need Ubuntu (Linux) for this? D...
ReadySECURE
Dec 04, 2012Apprentice
The drives are formatted with ext as mentioned above, but you also have to take into account that the ReadyNAS is a RAID unit, so you would have to have at least the minimum required amount to run the RAID in order to access the files (RAID 5 is total number of disks minus one disk, RAID 6 (dual disk redundancy) is the total number of disks used minus two. RAID 1 would be mirrored disks of each other and would be able to easily extract the data. If you want to use the disk and no longer have it in a RAID setup, you'll most likely have to mount the disk using Disk Utility and wipe all partitions.
