KentZ
Aug 25, 2021Follower
Access old files Using iMac
Hi, Since Apple updated iMac to 64 bit in yrar 2000 i can”t access my old files on my readynas duo any more... Raidar 4.1 only works using older systems from Apple. Anybody have a work around? ...
Aug 26, 2021Guru - Experienced User
KentZ wrote:Since Apple updated iMac to 64 bit in yrar 2000
I think you got the date wrong. Plus it's not about 64 bit vs 32 bit.
Do you have AFP enabled on the NAS? I believe that will work. You could also try using cifs:// in finder instead of smb:// and see if that helps.
