gsabo
Aug 04, 2020Aspirant
Accessing ReadyNas RN31200 without networking
I have a ReadyNas device that I believe has an issue with its LAN ports, I am unable to discover this device from ReadyCLOUD or with RAIDar. I am looking to see if there is any other way to access th...
Aug 04, 2020Guru - Experienced User
If the LAN ports are in fact broken, you will either need to
- Get a replacement OS-6 ReadyNAS and migrate the disks or
- Connect the disk(s) to a PC and mount them with suitable tools
On the second option - there is a beta version of btrfs and mdadm for windows that could be used. Of course the linux btrfs and mdadm could be used as well. If the volume is damaged, you could use ReclaiMe raid recovery software.
If you are the original purchaser, you should check your warranty status (5 years for the original purchaser).
Did you try RAIDar with the disks removed from the NAS? If the LAN ports are working it normally will show up with a "no disks" status. That would rule out any issues with the disks (which sometimes can prevent the NAS from booting).
Also check the LAN led status on the NAS and your router/switch.
gsabo wrote:
I have attempted to reset this device without the drives in it
That cannot be done. The factory default (reset) formats the disks and installs linux and application software on them. It does nothing when disks are not installed.
A USB recovery can be done with the disks removed - though I don't think it is likely to accomplish anything if RAIDar can't find the NAS with the disks removed.
Sandshark
Aug 04, 2020Sensei
And maybe it goes without saying, but try both ports on the NAS, another cable, and another port on the router/switch. If you have a switch in the mix, perhaps also try connecting directly to the router.
