gsabo
Aug 04, 2020Aspirant
Accessing ReadyNas RN31200 without networking
I have a ReadyNas device that I believe has an issue with its LAN ports, I am unable to discover this device from ReadyCLOUD or with RAIDar. I am looking to see if there is any other way to access th...
Sandshark
Aug 04, 2020Sensei
And maybe it goes without saying, but try both ports on the NAS, another cable, and another port on the router/switch. If you have a switch in the mix, perhaps also try connecting directly to the router.
gsabo
Aug 05, 2020Aspirant
Thanks for the reply, I have tested it with known good network connections but to be safe have used a few different ones but still no luck
- SandsharkAug 05, 2020Sensei
Are you also observing any issues turning the unit on and off? I ask because the NIC components and power-on circuit use the same power source, which remains on, even when the rest of the unit is off. But the fact that those components remain on can also be an issue if the unit was ever left where it was plugged in and the temperature got very high. I don't think Netgear (or PC manufacturers, many of which do the same thing) warn you about that. Many users assume it will be OK if it's "off".
A nearby lightning strike can also be a cause for failure of NIC components, especially if the incoming network connection and power have different ground points. I have two DuoV2 units with lightning damage (I bought them that way for parts), though not total loss of Ethernet. Neither will negotiate a proper connection on a "green" switch or over a long cable, but you can see LED activity as they try.
If you see absolutely no activity on the LAN LEDs, then the problem is not in the flash memory, it's the NIC or power distribution and is non-repairable. The process is here: How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system if you still want to try it.
