G_man1
Jul 26, 2012Aspirant
Act light flashing but nothing is connected.
Hi, not sure if I'm in the right section I've noticed on my ultra 2+ that the activity light is flashing say twice or three times every 5 seconds or so. When it flashes I can hear my hard drives cl...
G_man1
Aug 17, 2012Aspirant
Is this the log you were after?
***** smartctl output for sda *****
smartctl 5.42 2011-10-20 r3458 [x86_64-linux-2.6.37.6.RNx86_64.2.4] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Hitachi Deskstar 7K3000
Device Model: Hitachi HDS723020BLA642
Serial Number: MN1220F322D53D
LU WWN Device Id: 5 000cca 369dd456a
Firmware Version: MN6OAA10
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Fri Aug 17 13:05:32 2012 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 24) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 88
3 Spin_Up_Time 0x0007 132 132 024 Pre-fail Always - 435 (Average 434)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 138 138 020 Pre-fail Offline - 25
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 452
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 31
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 31
194 Temperature_Celsius 0x0002 181 181 000 Old_age Always - 33 (Min/Max 17/36)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
***** smartctl output for sdb *****
Serial Number: MN1270F33HJEMD
LU WWN Device Id: 5 000cca 369f155ca
Firmware Version: MN6OA800
ATA Version is: 8
Local Time is: Fri Aug 17 13:05:33 2012 EST
been run.
data collection: (18950) seconds.
command.
power-saving mode.
2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 87
3 Spin_Up_Time 0x0007 132 132 024 Pre-fail Always - 432 (Average 433)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 86
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 1049
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 86
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 86
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 86
194 Temperature_Celsius 0x0002 193 193 000 Old_age Always - 31 (Min/Max 16/37)
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
