fwdnetad
Jun 06, 2016Aspirant
Active Directory issues after 6.5 upgrade
So after the the 6.5 update on our ReadyNAS 516 we are experiencing some weird issues with active directory permission to the NAS. Some users can get right on while other users it just keeps prompti...
- Jun 15, 2016
Hi,
Try to load the latest RC Beta Firmware 6.5.1 and see if it resolves your AD issues. If you're hesitant, continue to work with our support team.
Kind regards,
BrianL
NETGEAR
BrianL2
Jun 08, 2016NETGEAR Employee Retired
Hi fwdnetad,
Were the groups and users properly imported or remained after the Firmware update? Also, send me a PM together with the device ads log and systemd-journal log.
Kind regards,
BrianL
NETGEAR Community Team
fwdnetad
Jun 08, 2016Aspirant
I will send that PM to you tomorrow when I get back in the office.
I tried enabling the "do not cache accounts locally" option and I was then able to access the shared with any user. Though using this method the permissions on the folders are messed up. If I look at the security tab in the folder properties all the usernames now read "32982 (Unix User\32982)". Of course the number is differnet with each user.
