wifiuk
Aug 31, 2013Aspirant
Added 2nd Larger Disk
I have a ReadyNAS Duo v2 i have a 1TB disk full, so i have added a 2nd disk, a 3TB drive. It has XRAID on it and now says /c X-RAID2 (Redundant) 1 GB Free Of 913.4 GB i need to free ...
Aug 31, 2013Guru - Experienced User
You'd need to upgrade your 1TB drive to 3 TB to get the additional space. After that, you'd have 3 TB of total space, and protection against a single drive failure.
The other option would be to buy a backup USB drive, copy all your data to it, and then do a factory reset (which will wipe your data) and use flexraid. Then you would end up with 4 TB of total space but no protection against drive failures.
Since you are using your NAS for primary storage, you really need a backup anyway. Without one you will lose your data - it is only a mater of when.
