ggoosen
Nov 27, 2013Follower
Adding 3TB drive on RN104 - Taking more than 30 hours
Hi All, Simple question (i think) Is it normal to expect that the additon of a drive to a readynas would take 30-???? hours to "rebuild" I bought the NAS on Saturday and placed 1 3TB drive in...
vandermerwe
Dec 11, 2013Master
You are saying you told the NAS to shutdown while it was resyncing?
The device should have been online while the resync was taking place.
I think you should contact support, or if you have a backup you could force a shutdown by pushing and holding the power button. Then see what happens when you reboot. If a resync was interrupted, it should continue.
The missing info in raidar is a known problem so don't worry about it.
