ggoosen
Nov 27, 2013Follower
Adding 3TB drive on RN104 - Taking more than 30 hours
Hi All, Simple question (i think) Is it normal to expect that the additon of a drive to a readynas would take 30-???? hours to "rebuild" I bought the NAS on Saturday and placed 1 3TB drive in...
vandermerwe
Dec 11, 2013Master
If the display says shutting down then the unit has hung and is not resyncing. The device should function ( albeit a little slower) during a resync and the GUI should be accessible. Your NAS is not in this state.
The 104 needs to be unplugged to force a shutdown.
The 4th disk may be the problem here.
Do you have a backup - this is also advised prior to any volume expansion manoeuvres.
