rmaeder
Apr 04, 2011Aspirant
Adding a disk to ReadyNAS Pro for RAID5/6 volume expansion?
I have been running a Pro Business unit with 4 2TB disks, configured with one RAID5 and one RAID6 volume. Now, I added another disk and want to extend the two volumes to use the new disk. Frontview on...
rmaeder
mdgm wrote: On 4.2.16 (due for a production release soon),
I don't know if you can do similar with Flex-RAID. You can however expand Flex-RAID volumes on 4.2.16 as indicated here: http://www.readynas.com/forum/viewtopic.php?p=279423#p279423
that would be exactly my case:
Horizontal Expansion: only RAID5 and RAID6 as you are adding next disk into current RAID array.
so the answer is to wait for the 4.2.16 release?
If I add the disk as a hot spare now, would I still be able to use it to extend the volume later on, or should I wait?
