geojay
Apr 16, 2020Guide
Adding disk to volume on RN214
My RN214 currently has two 4TB disks inside, arranged as a single X-RAID volume (RAID 1). I've added a third 4TB disk and was expecting the volume to expand automatically onto the new disk. Apart fro...
Marc_V
Apr 16, 2020NETGEAR Employee Retired
If it's on X-RAID it should auto Expand and change to RAID5. Are you seeing the Expand button on the Volume info?
If it has the expand button enabled, it probably might have changed to Flex-RAID but it should not happen without intervention as well. Have you tried inserting the drive on another bay? Are you getting any message or error?
Regards
