geojay
Apr 16, 2020Guide
Adding disk to volume on RN214
My RN214 currently has two 4TB disks inside, arranged as a single X-RAID volume (RAID 1). I've added a third 4TB disk and was expecting the volume to expand automatically onto the new disk. Apart fro...
Marc_V
Apr 16, 2020NETGEAR Employee Retired
If it's on X-RAID it should auto Expand and change to RAID5. Are you seeing the Expand button on the Volume info?
If it has the expand button enabled, it probably might have changed to Flex-RAID but it should not happen without intervention as well. Have you tried inserting the drive on another bay? Are you getting any message or error?
Regards
geojay
Apr 16, 2020Guide
Hi Marc,
I don't see an Expand button on the volume screen (see attached screenshot). When I added the third disk I got the following message:
"Disk: Disk Model:ST4000VN008 Serial:ZGY6MAM2 was added to Channel 3 of the head unit.". I've had no error messages...
I have only inserted the disk once so far...
Thanks
