geojay
Apr 16, 2020Guide
Adding disk to volume on RN214
My RN214 currently has two 4TB disks inside, arranged as a single X-RAID volume (RAID 1). I've added a third 4TB disk and was expecting the volume to expand automatically onto the new disk. Apart fro...
geojay
Apr 16, 2020Guide
Hi Marc,
I don't see an Expand button on the volume screen (see attached screenshot). When I added the third disk I got the following message:
"Disk: Disk Model:ST4000VN008 Serial:ZGY6MAM2 was added to Channel 3 of the head unit.". I've had no error messages...
I have only inserted the disk once so far...
Thanks
Apr 16, 2020Guru - Experienced User
What happens if you select the disk on the volume tab, and the click on format in the right pane?
If the disk is formatted outside the NAS, it won't be automatically added to the array.
- geojayApr 16, 2020Guide
Hi Stephen,
It was a brand new disk and I've tried formatting it using the Format option. This seemed to have no effect. The attached screenshot shows the current status of the disk as obtained by hovering over the disk...
Thanks
- StephenBApr 16, 2020Guru - Experienced User
geojay wrote:It was a brand new disk and I've tried formatting it using the Format option. This seemed to have no effect.
Was there any indication in the UI that formatting was actually done?
Try rebooting the NAS, and see if that triggers the expansion.
Hi Stephen,
I got the following success message from the logs:
"Volume: Disk format completed on channel 3."
I've rebooted once following the format but I'll try again...
Thanks
