malcmail
Sep 04, 2015Aspirant
Adding users
This will seem like the stupidest question in history bu bear with me. Just got a hold of a RadyNAS104. Drives in, software updated, all looking good. Until I come to add users. Added one. Didn't ap...
- Sep 04, 2015
Solved - SSH'd to the box and deleted myself. Seemed OK to re-add after that. Weird.
malcmail
Sep 04, 2015Guru - Experienced User
Did you have a share set up with the same name?
- malcmailSep 04, 2015Aspirant
Nope - hadn't set a thing up since I got it. Of course now I'm struggling to find out where to set up home directories. Googled it but looks like the instructions were pre update.
- StephenBSep 04, 2015Guru - Experienced User
You don't. You just set up the user account, and the home directory is created the first time they log in.
- malcmailSep 07, 2015Aspirant
Thanks for the help. When you say log in.... To the admin dashboard? By SMB etc?
