Woodie1
May 08, 2017Aspirant
Admin page behavior different on two separate ReadyNAS 316 systems - no SSL?
My main RN316, version 6.7.1, began starting to load the admin page, displaying the system overview, and then re-loading the admin page over and over several weeks ago. My second RN316 system, also 6...
Woodie1
May 10, 2017Aspirant
Hi Jenn,
Thank you! Both connect on Chrome with no SSL, but only the Backup-NAS connects on Safari, also with no SSL. Shares are visible and work fine on the Mac finder. Anti-virus running on both units. How do I attach the logs to my reply?
Best,
Woodie
Woodie1
Sorry, found the answer, logs sent.
- JennCMay 10, 2017NETGEAR Employee Retired
Hello Woodie1,
As discussed, you have used multiple computers and browser, cleared browser cache, no SSL, SSH is also not enabled as I checked on the logs and you have also sent the logs, I will check as well with others what could be causing it.
- mdgm-ntgrSep 05, 2017NETGEAR Employee Retired
Do you still have this problem?
- Woodie1Sep 05, 2017Aspirant
No, I was able to solve it, thanks.
