tec-man
Mar 14, 2018Guide
Admin page issue after upgrade
I have 2 and 4 bay NAS drives. I upgraded from 6.9.2 arm to 6.9.3 arm. Upgrade proceeded normally. After reboot the splash screen indicated 6.9.3 and then "Connection to ReadyNAD Admin Page". The...
tec-man
Mar 15, 2018Guide
Problem solved.
(Moderator) Bryan followed up with me. Using device logs and then remoting in he was able to solve the problem.
Great support from Netgear on the issue.
paul
Magnus_J
Mar 16, 2018Aspirant
Hi,
I have the same issue. What was the solution?
Thanks
//Magnus
- mdgm-ntgrMar 16, 2018NETGEAR Employee Retired
Can you download your logs using RAIDar as well and send those in please?
- tec-manMar 16, 2018Guide
I do not know what was done. Bryan remoted in and must have made changes to code or parameters.
paul
- Rolf-deMar 16, 2018Aspirant
Hello, same problem here.
Logs were sent to Slas but we have no connection to the web and so it can't be remote connected.
Is there a solution without connecting remote to the NAS?
Rolf
It was indicated that the fix will be in the next update 6.9.4
paul
