tec-man
Mar 14, 2018Guide
Admin page issue after upgrade
I have 2 and 4 bay NAS drives. I upgraded from 6.9.2 arm to 6.9.3 arm. Upgrade proceeded normally. After reboot the splash screen indicated 6.9.3 and then "Connection to ReadyNAD Admin Page". The...
Jürgen
Mar 18, 2018Aspirant
I have the same problem. After rebooting the volume is inactive and so all shares are not reachable anymore.
I tried disk-check via boot-menu and afterwards I could at least reach the admin-page again. But it shows now that volume is inactive and volume-usage is at 100%. What can I do?
Juergen
ReadyNAS2120v2 with 4x 4TB
- mdgm-ntgrMar 18, 2018NETGEAR Employee RetiredJürgen do you have a backup?
You can send your logs in if you like (see the Sending Logs link in my sig).- JürgenMar 18, 2018Aspirant
I have a backup on my old RN2100, but because that one has smaller HDUs, not of all shares. I have a backup of only the most important data.
As I do backups of my MacOS-clients also on USB-HDUs I could live with loosing the share "Backup" on my 2120, bu therefore recover the rest, if possible in any way.
In that case you should contact support.
