tec-man
Mar 14, 2018Guide
Admin page issue after upgrade
I have 2 and 4 bay NAS drives. I upgraded from 6.9.2 arm to 6.9.3 arm. Upgrade proceeded normally. After reboot the splash screen indicated 6.9.3 and then "Connection to ReadyNAD Admin Page". The...
atireach
Sep 25, 2018Aspirant
In 6.9.3 (readynas 3138) it intermittently works but after upgrading to 6.9.4 the admin portal no longer loads. Can somebody assist or provide a solution? I am still able to access the files by windows explorer; just no longer can access the admin portal page.
- KingOfPainOct 15, 2018Tutor
While Googling "readynas 104 admin page randomly failing", it would appear that I am not alone. :(
Should I take a gamble and load the 6.10.x beta FW or have someone officiall take a look at the logs?
Thanks
- KingOfPainOct 17, 2018Tutor
In case it helps anyone else, the problem I had was due to the a previoius login that had persisted. Once I forced a logout, it was back to normal.
- bedlam1Oct 18, 2018Prodigy
How did you force the logout and where please
