tec-man
Mar 14, 2018Guide
Admin page issue after upgrade
I have 2 and 4 bay NAS drives. I upgraded from 6.9.2 arm to 6.9.3 arm. Upgrade proceeded normally. After reboot the splash screen indicated 6.9.3 and then "Connection to ReadyNAD Admin Page". The...
KingOfPain
Oct 15, 2018Tutor
While Googling "readynas 104 admin page randomly failing", it would appear that I am not alone. :(
Should I take a gamble and load the 6.10.x beta FW or have someone officiall take a look at the logs?
Thanks
KingOfPain
Oct 17, 2018Tutor
In case it helps anyone else, the problem I had was due to the a previoius login that had persisted. Once I forced a logout, it was back to normal.
- bedlam1Oct 18, 2018Prodigy
How did you force the logout and where please
- KingOfPainOct 25, 2018Tutor
If you still see your "admin" user in the upper right, and you can still get to it, then you can logout. I've enabled SSH so I can fix/manage some of this stuff easier w/o having to trely on the web GUI.
I think this issue may be more complicated though. I think there may be some secondary issues occuring with Chrome and how it is handling the SSL certificate as "invalid", which it kinda is. (SSL is only valid when used on a FQDN, not an IP address).
- StephenBOct 25, 2018Guru - Experienced User
KingOfPain wrote:
I think this issue may be more complicated though. I think there may be some secondary issues occuring with Chrome and how it is handling the SSL certificate ....
Loss of access to the admin page shouldn't be related to certs (though if you haven't installed a CA cert you will need to click-through security warnings in most browsers).
