Machforr2
Oct 04, 2021Aspirant
Admin/passwords stopped working, NAS unaccesible despite Raidar seeing it.
Of course it had to happen on a monday when I need to work. It was working fine the friday before, of course. Raidar Sees the NAS, as it should, however trying to access it normally does not work a...
- Oct 11, 2021
Going to a factory fresh condition may be the route of least resistance. But since you are doing that, you may want to consider moving to OS6, which can run (unofficially, meaning no Netgear Support) on your Ultra. It is recommended you upgrade to 2GB of RAM if you've not already, but it's widely available and inexpensive DDR3 RAM and an easy swap.
In addition to getting a more up to date OS (though it is getting long in the tooth), you gain the ability to simply move your volume to a native OS6 unit if the Ultra finally fails on you or you just want to go with a faster/larger NAS.
Machforr2
Oct 05, 2021Aspirant
First, I apologize for the double post... ibcould not fined my original one after registering, thought it lost.
And I am 90% sure it is running Raidiator, as I did not update the firmware since 9 years ago at least.
I did manage to access the data from a win7 machine, saving the content, but I still can't get setup to work.
Thank you for reaching out, much appreciated.
Oct 05, 2021Guru - Experienced User
9 years ago is a long time - 4.2.31 was released in 2017. You should update the firmware when you regain access. https://kb.netgear.com/000038793/RAIDiator-x86-Version-4-2-31
Have you tried browsing directly to https://nas-ip-address/admin (using the real IP address of the NAS)? Is the issue that the NAS won't accept the admin login, or is it something else (like not getting to the page at all)?
If this is a windows 10 PC, you need to enable the SMB 1/CIFS client in indows to access the shares. You do that in "turn windows features on or off". There is a security warning that you will need to ignore.
