Machforr2
Oct 04, 2021Aspirant
Admin/passwords stopped working, NAS unaccesible despite Raidar seeing it.
Of course it had to happen on a monday when I need to work. It was working fine the friday before, of course. Raidar Sees the NAS, as it should, however trying to access it normally does not work a...
- Oct 11, 2021
Going to a factory fresh condition may be the route of least resistance. But since you are doing that, you may want to consider moving to OS6, which can run (unofficially, meaning no Netgear Support) on your Ultra. It is recommended you upgrade to 2GB of RAM if you've not already, but it's widely available and inexpensive DDR3 RAM and an easy swap.
In addition to getting a more up to date OS (though it is getting long in the tooth), you gain the ability to simply move your volume to a native OS6 unit if the Ultra finally fails on you or you just want to go with a faster/larger NAS.
Machforr2
Oct 05, 2021Aspirant
Raidar is showing "4.2.17". That's after the OS reinstall, I don't recall if an update writes itself to the backup flash or if that's the actual original shipped firmware.
mdgm
Oct 06, 2021Virtuoso
I think that firmware was released over 10 years ago.
When you update the firmware the firmware is updated on the flash and then installed onto the disks, so the firmware on your system is consistent with you never having updated it.
- StephenBOct 06, 2021Guru - Experienced User
If you still can't access https://nas-ip-address/admin from any PC, then I suggest trying internet explorer as the browser. If you click on the settings for it, you will see "compatibility view". I'd add https://nas-ip-address to the compatibility view list in the browser. Not sure if this is required, but I have some recollection that it helped with some old firmware.
Also, if you have any internet security software running (Kaspersky, Avast,Norton etc), or "safe browsing" extensions then try disabling that stuff.
- Machforr2Oct 06, 2021Aspirant
StephenB wrote:If you still can't access https://nas-ip-address/admin from any PC, then I suggest trying internet explorer as the browser. If you click on the settings for it, you will see "compatibility view". I'd add https://nas-ip-address to the compatibility view list in the browser. Not sure if this is required, but I have some recollection that it helped with some old firmware.
I did try to use internet explorer before, however the compatibility view is something I didn't know existed and gave it a shot, along with disabling anti-virus and windows' firewalls.
While it didn't work, it opened another can of worms in that I get a certificate error pertaining to the IP address 192.168.3.2. That is the IP I set personally before the reset, however Raidar shows 192.168.168.168 and is the only IP that brings up the login prompt (the *.3.2 IP gives a timeout)
I tried getting the certificate installed by opening IE with admin previleges, no dice.
I'll point out that I now have a backup of the NAS's data, so any action that wipes out the drives or 'may damage files' could be explored if needed.
- SandsharkOct 07, 2021Sensei
The IP assignment changing from static to DHCP is another thing an OS re-install does. But an address of 192.168.168.168 is not normal. Are you connected directly from the computer to the NAS, with no router in between as DHCP server? If so, do you have your computer configured to an address of 192.168.168.x? I think you must, but just confirm.
The certificate thing is something you can't get around iin Win10. Just accept it and move on. That you are getting that far is a good sign.
- Machforr2Oct 07, 2021Aspirant
You are correct, I'm connected directly to the NAS from my PC without a router in-between.
I also confirm that my PC's network adapter that goes to the NAS has been manually set up to an IP address 192.168.168.1.
When I tried the old IP address, I would get a timeout error without even a login prompt.
I managed to get the certificate installed with the correct address, too, however I'm still not granted access.
I'm considering a USB recovery to reinstall the Raidiator, but I'll deffer to your experience. You guys are real troopers, I really appreciate the time you're giving me :)
I don't think that you have a RAIDiator problem other than it being very old. A USB recovery is not your best path unless it's also an update to the latest OS (which I don't recommend unless one of the Netgear or former Netgear folks tells you it's safe from your current version). There was a point in the RAIDiator development that changes in browsers caused users to have to use the IE compatibility mode already discussed until a RAIDiator update came along, and you likely are at a point earlier than that. Whether or not there were additional changes downstream that would add to your difficulty in logging on with a much newer browser than your RAIDiator version, I just don't recall.
Any chance you can try with a Windows 7 virtual machine, or even an actual old Win7 system?
You can download a legit (but time-limited) Win7 VM from Microsoft here: https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
I did try on an actual Win7 system with IE in compatibility mode.
Even with the certificates installed and the network adapter set correctly, I still get into the same login loop where the default admin/netgear1 doesn't work.I also tried my old login/password in case it didn't get reverted and it also didn't work.
I'll say that not having access to RAIDiator is fairly recent, as just a few months back I still had access to it. Having changed both hard drives last year, I had to set them up. I regularly logged in to check health and temps.
- StephenBOct 08, 2021Guru - Experienced User
Machforr2 wrote:
Even with the certificates installed and the network adapter set correctly, I still get into the same login loop where the default admin/netgear1 doesn't work.Do you have any internet security software installed (avast, kaspersky, norton)? If so, disable it. Also disable popup blocking in the browser
One thing you can also try is downloading and installing old version of firefox. Don't let it update. Perhaps this version: https://ftp.mozilla.org/pub/firefox/releases/52.0.2/
BTW, I recommend clicking through security exceptions for now, and not attempting to update certs.
I am assuming that ssh is not enabled - is that the case?
- Machforr2Oct 08, 2021Aspirant
I'm currently using PandaDome and tried with it both on (as it used to work) and off, as suggested and while I did manage to try an older firefox (not quite as old as version 52) I ran into the same loop that just keeps asking for login/password despite providing what should be the correct credentials. (admin/netgear1)
For the SSH, I had to look it up, as I never had to touch this particular setting and, according to the 2018 win10 update that it came with, it's enabled by default and has been enabled for as long as it's been there.
I strangely noticed that despite having done an 'os reinstall' using the manual's directions, the NAS has kept the 'power on/power off' schedules that I has set up, which I find odd, since the IP has been reset. Unless I'm mistaken and the OS reinstall does not affect anything other than IP and login/password.
I'll give a shot at all that on the win7 system too and see what happens.
I'm quite stumped as to what's happening.
Thanks again for the extra options, sorry it's being stubborn like that.
The OS reinstall will
- reset the admin password back to netgear1
- reset the network configuration to use DHCP with no bonding
Other settings should remain intact (including the power schedule).
You could try doing the OS reinstall again.
One thing you could alternatively try is to
- remove all disks (labeling by slot)
- insert an unformatted spare disk
- power up
That will do a fresh factory install. If you have admin access at that point, you could upgrade the firmware to 4.2.31. Then power down and reinstall the original disks. When you power up again, the boot loader will upgrade the OS on the disks to 4.2.31.
- Machforr2Oct 10, 2021Aspirant
Allright, good news/bad news time:
Removing my disks and starting the NAS with a new, unformatted disk had the desired effect: I got access to the setup even in the latest firefox and upgraded the old firmware to the 4.2.31 version of it. I didn't dare go further, baby steps and all that.
After doing that and removing the 'donor disk' and putting back my old drives, the NAS refused access once again, going back into its old login loop.
My guess at this point is that there is some bad sector somewhere on one or both the disks and I'm tempted to unformat both and re-insert them, starting from scratch. Worry not, all data has been backed up and accounted for.
Think this course of action would work or would you recommend installing an even newer firmware using the 'donor disk' method?
I feel we're getting there, thanks again for the amazing support so far :)
- SandsharkOct 11, 2021Sensei
- Machforr2Oct 11, 2021Aspirant
And it worked!
Factory reset did indeed allow me back into the setup in the end, without going through hoops with a different browser as the current Firefox version allowed me access.
I haven't installed OS6 yet, mostly due to the RAM limitation. My first cursory look through the knowledge base didn't give me any answer however as to which RAM vendors are compatible with the RNDU2220 that I have. Is there such a list available or a forum post with one?
I do have a Corsair 8gb SoDimm lying around, due to it not being compatible with the tablet I wanted to put it in. (I realized it was not compatible after the fact, forgetting to check for a compatibility list). But that might be both too much and way overkill for the system to handle.
I'll put the previous message as the solution to my problem, however, since it did get me to access the setup for my NAS :)
You guys are real troopers! :)
Any standard DDR3-1066 (PC3-8500) or faster RAM SO-DIMM (laptop RAM) should work. While the CPU should, theoretically, accept 4GB, what I've read seems to indicate it has to be in two slots, which the Ultra2 does not have. It most definitely does not support 8GB. I don't know if it supports low voltage RAM (PC3L), so best to avoid it. 2GB will cost on the order of $5 or $6 on eBay.
I've used mostly DDR3-1333 (PC3-10600) due to availability.
- Machforr2Oct 12, 2021Aspirant
Sandshark wrote:Any standard DDR3-1066 (PC3-8500) or faster RAM SO-DIMM (laptop RAM) should work. While the CPU should, theoretically, accept 4GB, what I've read seems to indicate it has to be in two slots, which the Ultra2 does not have. It most definitely does not support 8GB. I don't know if it supports low voltage RAM (PC3L), so best to avoid it.
Hm.. I suspected as much. Better to know now than break something trying, that's for sure.
That being said however, everything is back up and running. Currently slowly repopulating the NAS with the backed-up files and it's definitely good to know that the drives inside didn't seem to have suffered.
All of your help was invaluable in terms of problem solving experience with this :)
Hopefully this will help others with a similar issue, too!
