Machforr2's avatar
Machforr2
Admin/passwords stopped working, NAS unaccesible despite Raidar seeing it.
Of course it had to happen on a monday when I need to work.  It was working fine the friday before, of course. Raidar Sees the NAS, as it should, however trying to access it normally does not work a...
  • Sandshark's avatar
    Sandshark
    Oct 11, 2021
    Going to a factory fresh condition may be the route of least resistance.  But since you are doing that, you may want to consider moving to OS6, which can run (unofficially, meaning no Netgear Support) on your Ultra.  It is recommended you upgrade to 2GB of RAM if you've not already, but it's widely available and inexpensive DDR3 RAM and an easy swap.
    In addition to getting a more up to date OS (though it is getting long in the tooth), you gain the ability to simply move your volume to a native OS6 unit if the Ultra finally fails on you or you just want to go with a faster/larger NAS.
ProSupport for Business
