raven219
Jan 03, 2014Aspirant
Advice on files crashing ReadyDLNA scan
Hi Could you advise why these files would cause the ReadyDLNA scan to fail? I discovered that it was these ones by going through the log files and using the command to move the offending director...
raven219
Jan 07, 2014Aspirant
Thanks.
1. Re-encoded with 4.1 profile
2. Header compression and tons of sub titles removed.
3. As 2.
All works.
3. As 2.
All works.
