cspry
Jan 19, 2014Aspirant
Advice requested to expand my ReadyNAS NV+ 3 TB
On 3/6/2007, I received and installed a Netgear (Infrant) ReadyNAS NV+ 3 TB. It has four 750 GB Seagate AS disks in default RAID X configuration. Today I installed the latest firmware for it, RAIDiato...
vandermerwe
Jan 19, 2014Master
Start by reading this:
http://www.rnasguide.com/2011/06/22/wha ... as-volume/
and see the compatibility list (select legacy devices):
http://www.readynas.com/?page_id=82
You can only use up to 2 tb sized disks with the readynas NV+.
You may find that a lot of the disks are no longer available in which case I'd go for the Seagate NAS drive or WD Red NAS drive.
You must backup your data before starting this process.
