cspry
Jan 19, 2014Aspirant
Advice requested to expand my ReadyNAS NV+ 3 TB
On 3/6/2007, I received and installed a Netgear (Infrant) ReadyNAS NV+ 3 TB. It has four 750 GB Seagate AS disks in default RAID X configuration. Today I installed the latest firmware for it, RAIDiato...
vandermerwe
Jan 19, 2014Master
Consider the 314 if you can afford to.
Buy a diskless unit and choose your own drives, gives you more control over the drives you get and I think it works out cheaper.
If you are storing video especially he, I would consider a 6 bay Nas like the 316.
I reverse the functionality of the units, use the nv+ as the backup unit
