gilbreen
Feb 21, 2016Aspirant
AFP access not visible for all shares (Mac)
I have an Ultra 4 model that I recently upgraded to OS 6. I am in the process of moving the data from my backup to the ReadyNAS but am having some difficulty with AFP access. In the Admin page via t...
- Feb 22, 2016
You are connected as a guest to AFP and have guest access turned off for the Media share. You either need to enable guest access for the share or login as a user to AFP.
gilbreen
Feb 22, 2016Aspirant
Thanks for your response. I have checked the settings you mentioned and they are set the exact same as each other but only the Documents share is the one that shows up as an AFP share. I am wondering if I need to reset the NAS again. The default shares all showed up as AFP shares but any new shares I add, do not.
BrianL2
Feb 22, 2016NETGEAR Employee Retired
Hi gilbreen,
Are you running FW 6.4.2 in your system? Try disabling the AFP service under System->Settings and re-enable it afterwards. Rebooting the unit after this procedure would help.
Kind regards,
BrianL
NETGEAR Communit Team
