a_carneiro
Dec 02, 2017Tutor
AFP Connection Failure (Logs say disk full?)
Well, let me try this again. Maybe someone will actually reply this time... ;P Gave up on AFP access on my Readynas 214 but started having issues with my Pro 6. Out of the blue it started rejecti...
a_carneiro
Dec 03, 2017Tutor
No, but should be easy enough to do...
What do you suggest?
Dec 03, 2017Guru - Experienced User
try enabling ssh from the web admin ui (system->settings->services), and then access the NAS using terminal. The username is root, the password is the NAS admin password.
Then enter df // -h and tell us the response. Normally the OS partition will be ~25% full. My own NAS reports this:
root@NAS:~# df // -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 914M 2.8G 25% /
- a_carneiroDec 03, 2017Tutor
Hello again Stephen (and thank you for taking the time to help me!)
I get the output:
root@Titan:~# df // -h
/dev/md0 4.0G 1.3G 2.4G 35% /
root@Titan:~#
So it doesn't seem to be that... Any further thoughts? :/
- StephenBDec 03, 2017Guru - Experienced User
Maybe try deleting .AppleDB in the share. You could also try resetting the file permissions on the share and see if that helps.
