netracer
Nov 12, 2010Apprentice
AFP Not Working
So I've been beating my head against the wall trying to solve a problem with both a Macbook and Macbook Pro not being able to see the AFP share on my ReadyNAS Pro on my home network. I'm a Mac newbie...
Chewbacca
Nov 12, 2010Aspirant
There shouldn't any issues connecting via afp with SL.
Have you verified that you have afp enabled on the share and the correct access?
Are you seeing that it is connecting as as SMB share instead of a AFP when you do a get info on the share in finder?
So you are not having a issue with the NV+?
Can you try direct connect?
