dtarin
Dec 15, 2013Luminary
AFS and CIFS access not working but ReadyNAS remote works
I'm puzzled.
I have a readynas nvx running firmware 4.2.25.
CIFS and AFS have been working flawlessly for years for me and all of a sudden this morning none of my OSX or PC machines could access the server anymore. I thought something ominous had happened but I'm able to log in to the admin console over http and the health check is all good. There are no errors in the logs. None of my machines can connect though.
Curiously I tried ReadyNas remote from an OSX machine not on the local network and it works! I can access all the shares.
I'm not sure how to proceed. Any advice on what I can check?
- dtarinLuminaryI did upgrade to 4.2.25 a couple of days ago. Maybe it has a bug?
I'm considering rolling it back to what I had before. Is rolling back to an earlier firmware as easy as finding an older firmware file and loading it up? - dtarinLuminaryOkay so I reverted to 4.2.22 and some of my OSX clients can access the shares now. (haven't checked all of them yet).
None of my windows machines can access the server yet though. Seems like some sort of NetBIOS issue?? No idea how to debug this sort of thing.. - StephenBGuru - Experienced UserWhat happens if you open windows explorer, and enter \\NASIP\sharename (where NASIP is the IP address of the NAS, and sharename is a shared folder).
- dtarinLuminaryNot at the computer at the moment but I did try using both host name and ip and I received an error along the lines of "can not access network path". I'm able to access FrontView just fine.
I also tried accessing the C share using \\NASIP\C and got the same error.
For kicks I decided to try and telnet to the smb port on the ReadyNAS to test if the port was open and receiving connections and I was able to connect. I don't recall the port number I tried (I think it was 445?) - StephenBGuru - Experienced UserWhat version of Windows are the PCs running?
- dtarinLuminaryWindows 7 machines primarily. The issue is now gone and it was a Windows 7 specific problem. I unmapped all network drives. I then went in to the networking section and reinstalled the network driver. I remapped the network drives and then I was able to access the drives again. Not sure exactly what was wrong but the network driver reinstalled fixed it. ReadyNas back to running latest version.
