dsnpevl
Jan 02, 2015Virtuoso
After backup: Destination is read-only?
I'm working on implementing a proper backup procedure as most experts on this forum recommend. But when trying to backup a large amount of data, I keep getting this error message: Backup: Error bac...
- Aug 01, 2015
Have been looking for a solution for this problem for a long time, but never managed to find the root cause.
In the end, I decided to remove the offending subdirectory that contained a file backup of a Windows system. This solved the problem with the backup procedure.
dsnpevl
Jan 03, 2015Virtuoso
Yes, did that with every disk and the scan/fix (chkdsk) will fix system file errors if they exist. And after that, I can switch off the read-only bit on the affected directory. But that still doesn't ensure me if the backup is complete and valid. And next time I do another full backup on the disk of the same data, the problem occurs again. So I'm first trying to figure out what is causing the read-only to be set in the first place, so I can find a way around it.
The logs in FrontView only offer one line of error message: "Backup: Error backup job 'data to USB_HDD_4': destination is read-only". But there I cannot find any root cause. This makes me distrust the whole quality of the backup. And if I cannot trust the quality of the backup, I cannot implement a proper backup procedure either, what is my goal to begin with and is strongly recommended here.
Is there a way to figure out which file(s) on my NAS would cause the read-only flag to be set on the external NTFS disk, in order to get to the root cause of this problem?
