dsnpevl
Jan 02, 2015Virtuoso
After backup: Destination is read-only?
I'm working on implementing a proper backup procedure as most experts on this forum recommend. But when trying to backup a large amount of data, I keep getting this error message: Backup: Error bac...
- Aug 01, 2015
Have been looking for a solution for this problem for a long time, but never managed to find the root cause.
In the end, I decided to remove the offending subdirectory that contained a file backup of a Windows system. This solved the problem with the backup procedure.
mdgm-ntgr
Jan 04, 2015NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs) link in my sig?
Do you still have this issue if you connect the USB disk to the front USB port on the NAS?
